This command specifies whether to forward or drop BPDUs when STP is disabled.
bpdu-forwarding | Specifies forwarding or discarding spanning tree BPDUs when STP is disabled. |
on | Forward STP BPDUs when spanning tree is disabled (default). |
off | Drop STP BPDUs when spanning tree is disabled. |
The default is on.
Error: All Spanning Tree Domains must be disabled globally before configuring stpd bpdu-forwarding off.
Error: Spanning Tree Forwarding must be enabled globally before configuring filter-method.
The following example disables BPDU forwarding when STP is disabled:
configure stpd bpdu-forwarding off
This command was first available in ExtremeXOS 22.1.
